Charudatta Bandgar
Forum Moderator
Damian,
If your curves are continous closed loop, you should be able to use the fill option to fill the surface. Are you facing any issues? If the fill option is not working, it is possible that it is not closed. Once it is filled to create a surface, it can be extruded using pull feature.
Charudatta
