Mateusz Piecuch
I just managed to solve the problem, by removing postProcessing objects (pathlines, contours, animations) defined in Fluent. As I thought, the problem was connected with writing one of these objects, probably due to some cluster settings. After deleting these objects my case is working well on cluster.
Thank you very much for your help, your info guided me to the solution.
Best regards
Mateusz
