Timothée Herbeau
Maybe I misunderstood the guides but I thought you could add solid and liquid material to the multicomponent particle, isn't it the case ? (And in that case, what model should I use to model a flow of droplet in which there is a solid suspension ? additionnaly what option can model those particles sticking to the walls they are projected onto -keeping in mind that the wall film does not suit my will to do steady simulation-)
Thank you so much for your help,
Have a good day
