November 8, 2023 at 2:31 pm
Thanks Natalie.
From the description, it looks like to me that loading is applied by moving the bearing in the vertical direction. If you're taking advantage of symmetry of the structure, I would suggest that you utilize symmetry regions (like the picture below) instead of manually imposing displacement BCs to represent the symmetry:
