November 8, 2023 at 11:26 pm
Hi Jordi,
- You mentioned that you calculated the power using the "dipolesource". I don't think there is a script command called "dipolesource". I guess you are either using dipolepower or sourcepower. The sourcepower script command does not give accurate result in the presence of multiple sources as it doesn't take into account the interference between the dipole sources. But if you are using dipolepower or a transmission box, you should be able to obtain the power accurately.
- Can you share a screenshot of the model with the simulation region? It's hard to predict if the simulation parameters are correct without looking at how the geometry has been set up.
Amrita
