November 9, 2023 at 5:38 pm
Hi Kavi
Select the Solution object in the Mechanical tree, then in the upper right of Mechanical select the 'Write Input File'. If you have an assembly and only want some parts, then first suppress the unneeded parts then write the input file.
Mike
