Jim Day
I have no doubt that others on the forum can address this sort of problem better than I can.
Did you check all the mes**** files for the word "Error"?
It may be good to make a general test of your HPC installation of MPP LS-DYNA.  Try running a smaller implicit model using multiple cores, keeping in mind you don't want to assign a lot of cores to a small problem.  Start with two cores.   You can find examples at dynaexamples.com.
