November 14, 2023 at 2:20 am
Dear Peteroznewman,
Thank you for your response.
I have followed the suggestions as given in your message.
Bonded Contact estabished at one end:
Bonded Contact estabished at another end:
bonded contact initial result is succesfull as shwon in green tick as below.
When we run the model, it shows the same error at that same node (ID 1756970) and stopped solution processing at 87% of structural run.
I also tried with using of bonded contacts of different other faces of problematic body to it adjacent body. But No sucess.
Please help. Thank you once again for your support.
Regards
AE
