November 14, 2023 at 2:35 am
You've set SURFATYP to 3 so that means SURFA is interpreted as a part ID. To put multiple parts on the slave side, you must set SURFATYP to 2 and then you can set SURFA to a part set ID. A part set is defined using *SET_PART.
