Saumadeep
Clicking on the "Show 7 Messages" option should show you the messages. But if that is not the case, try resetting the App Data:
Follow the steps below to reset ANSYS Appdata:
  1. Exit ANSYS, if you are using it currently.
  2. Go to Start > Run
  3. Enter %APPDATA%
    1. A folder explorer window will open
    2. Open the Ansys folder. Look for the Ansys version you are using, for example, v221, and rename it to v221_Old
  4. Launch ANSYS and refresh the project
Saumadeep
