November 16, 2023 at 12:41 pm
Forum Moderator
Yes, we only support the GPUs listed on the pdf that you have already found. Consider using the ANSGPU_OVERRIDE environment variable to override the check for valid GPU devices. Please note that you may not get optimal performance with hardware that is not on the list. Please check the following link for more info:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/ans_dan/gputrouble.html
-Aniket
