Bond Wolf
Thank you very much for your answer! What I'm thinking of is inserting stresses and strains as initial variables in the steady state thermal analysis, and then constructing a function about the stresses and strains via APDL commands. The function results are then added to the nodes as heat generation rate loads. Is this possible?
