November 20, 2023 at 2:04 pm
Hi Georgios,
Please check the following items:
- Check the contact between the gasket and the diamond. From the picture, it appears that a small interference is present in the results.
- Reduce the mesh size, particularly for the gasket. Capturing the bulge may require a finer mesh.
- Make sure proper boundary conditions are applied to the gasket, specifically for the free end of the gasket that may influence the resulting deformation field.
