Ren
Using the EDC model typically takes two steps:
1. Obtain a reasonably converged solution using an "easier" combustion model such as "Eddy-Dissipation" (EDM) or EDM + "Relax to Chemical Equilibrium" (RTCE). RTCE can be selected from "Chemistry Solver" dropdown menu in the Species Model dialog box. This soluton will provide a good flow field and temperature field as a starting point for EDC.
2. Switch to EDC and continue the calculation
