Bhargava Sista
Hi TimH
To transfer the temperatures from a transient thermal (TT) to a static structural (SS) system, you may create a connection between Solution of TT to Model of SS. This will create an "Imported Load" object under SS module. When you expand it, you'll find the object "Imported Body Temperature". You can specify the Source Time (the time at which the temperature is imported from TT) and the Analysis Time (the time at which the temperature is applied in SS). By default, the time under Source Time is set to "End Time" but you can change it to whatever time at which you would like to import the nodal temperatures from TT. Please refer to the attached image for more details.
