Sandeep Medikonda
Hello thanhttdt,
  In order to create a coupled analysis, you just need to drag one analysis system onto the other.
so for a figure a, drag and drop the geometry from the Component systems on the left-hand side of workbench project page and then drop a Static structural Analysis system onto it. Follow the same procedure for figure b as well where you can drag another Static structural analysis onto the Model cell.
Check out the thermal-structural analysis set up here:
Sandeep Medikonda
