thanhttdt
Hi Aniket,
Thanks for your suggestion
However, let me ask you that do I use Node force or Node pressure for Selected nodes?
Hi peteroznewman,
As you said "The next improvement would be if you can have those Upper and Lower Bound values be parameters"
It means that I can use parameter to change the tyre-print easily, right?
Now, I'm looking for new approach by using APDL code in workbench to choose Name selection and apply Node force. However, it's a little bit hard for me right now, so if you have any ideas, please give me some advice.
Many thanks
Best Regards,
