Ashish Khemka
You may apply the nodal force/ pressure in following way:
1. Create named selection. This creates a nodal component of the nodes in the input file for solver, same as creating a nodal component via CM command.
2. Insert a Commands object under the setup and define the commands:
CMSEL for selecting the nodes defined via named selection
F command to apply force
SF command for pressure on nodes
ALLSEL,ALL !Select Everything
