TimFethke
 Sandeep,
I do see a similar picture as to what you are referring to. However, if I want to perform the steps explained I run in to problems:
2. Enter the solution processor. On the ANSYS Main Menu, select “Solution”.
3. On the “Solution” menu, select “Analysis Type”, then “New Analysis”.
4. On the “New Analysis” menu, select “Substructuring/CMS”, and click “OK”.
The "Solution" object that you are pointing at does not have a menu where I can select Analysis type.
I do see something similar when I click on 'Static Structural' :
here
However, as you can see it is gray, and i cannot change that. Am i doing something wrong?
