Sandeep Medikonda
Can you insert a contact tool and check the status to see whats happening? Try to even increase the number of sub-steps so that the loads are applied more gradually and increase the pinball radius.
Also, what contact algorithm are you using?
Based on what you have described I think it would help if you used a nodal contact detection instead of the defaults (gauss integration points).
Checkout this useful article and see if it helps?
Sandeep
