DrAmine
I do not understand your static pressure plot: In which direction is it pointing.
Are you using ideal gas for you fluid or just constant density? If ideal gas I would recommend using a total pressure inlet or far-field boundary.  With far-field you can then get ride of the top and bottom symmetry.
Generally one would place the boundaries at a distance not smaller then 20 times the chord of wings.
A.
