tsiriaks
Hi Arthur,
Try this, open up Windows Explorer and paste the following into the address bar
%appdata%ansys
Once on this page, rename the v191 folder to anything else (such as v191.old)
If that doesn't help, check this
open up CMD Prompt, then issue the following command (this is for default installation path, if you've installed it in a non-default path, you have to change the path accordingly)
"C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util" -checkout aa_t_i
If your licensing is fine, you should see the output like
"..... INFO Demo license file  C:Program FilesANSYS IncANSYS StudentShared FilesLicensingstudent.lic exists.
aa_t_i OUT ....."
Thank you,
Win
