Hello Aya Hassan,
If your Fluent model was solving a Steady State flow, then the pressure at any point in the model is a static value that doesn't change with time. Then you would send that pressure result into a Static Structural model. You can have steady state turbulent flow, if you are doing Reynolds-averaged Navier-Stokes (RANS) in the model.
But if your Fluent model was a Transient flow simulation, then the pressure at a point in the model is a function of time and you would send that pressure result into a Transient Structural model.
