Karthik R
Administrator
Hello Joseph,
The model seems complicated. Here are a couple of things to try
  • Try to switch off the energy and radiation models and just solve the flow. Try to see if you are able to get good physical results for flow and VOF.
  • Attempt to build in the complexity layer by layer.
  • Try and use the explicit VOF formulation as opposed to implicit.
  • Please make sure that your are satisfying the CFL stability criterion.
  • Calculate your dimensionless numbers and double-check to ensure your Fluent model is set-up to solve the correct physics.
It is always a good practice to start small and built on top of that. Simplify your problem and resolve things one at a time. This will help you isolate your error.
Hope this helps.
Best,
Karthik
