Saransh
Thanks so much!
I got the current values that I was looking for from the first method that you described. This was indeed very helpful
For those referring to this question, first I added the J_vector in the stack, then took the Z component of it, then added the plane over which I was interested to calculate the total current in Z, and finally performed the integration! Hope this helps.
