DrAmine
From the pictures it looks plausible in almost all parts. Bu If I look in the volume rendering screenshots I see in the top of column 100% O2 which is wrong if you are describing proper opening boundary conditions and you are working with proper density definition. How did you patch the top part of your column? Did you patch a air composition here?
I would moreover work on deeper convergence. The settings regarding components are okay. I think the results are fair enough. Perhaps one of the community member might add a comment here because as an ANSYS Employee I am not able to add more than I have already done without looking into the case directly
A.
