Sandeep Medikonda
Hi ewold,
That is strange when you apply ramped loads, you should still see loads applied in a linear way along the sub-steps unless you are using a stepped (KBC, 1). So here is what I found from the manual:
  You can edit the table of load vs. time and modify this behavior as needed.
  By default you have one step. However you may introduce multiple steps at time points where you want to change the analysis settings such as the time step size or when you want to activate or deactivate a load. An example is to delete a specified displacement at a point along the time history.   You do not need multiple steps simply to define a variation of load with respect to time. You can use tables or functions to define such variation within a single step. You need steps only if you want to guide the analysis settings or boundary conditions at specific time points.   When you add loads or supports in a static or transient analysis, the Tabular Data and Graph windows appear. You can enter the load history, that is, Time vs Load tabular data in the tabular data grid. Another option is to apply loads as functions of time. In this case you will enter the equation of how the load varies with respect to time.
If you did not enter data at a time point then the value will be either a.) a linearly interpolated value if the load is a tabular load or b.) an exact value determined from the function that defines the load. An “=” sign is appended to such interpolated data so you can differentiate between the data that you entered and the data calculated by the program as shown in the example below. Here the user entered data at Time = 0 and Time = 5. The value at Time = 1e-3, the end time of step 1, is interpolated.
If this doesn't help? can you post some snapshots of what you are doing and how are the results drastically different?
Sandeep
