Inims
Kremella,
Thanks for your contribution.
I'm starting with a 2D bent pipe of 50mm diameter. You mentioned Fluent requires separate inlet to prescribe velocities. Does that mean I should divide the inlet into two and specify ''gas inlet & water inlet separately?
