Sandeep Medikonda
Maetha,
Are you using SpaceClaim? If so, Can you use the 'Show Contact' tool to look and make sure that the edges are being shared? Make sure to change Share Topology to 'Share' in the properties window.
Even in mechanical, you can check this by turning on 'Edge Coloring' > 'By Connection'. This will allow you to see if the edges are being shared between components.
~Sandeep
