Dear Peter,
thanks for your answer. I was also planning to use the Move tool in SpaceClaim to create parameters for a given angle. However, I was surprised to see that after I opened the geometry in SpaceClaim without changing anything and reset the contacts/ joints in Mechanical, my already-working solution failed to work completely with the new CAD format. You may remember the original problem from the previous post:
https://forum.ansys.com/forums/topic/help-with-choosing-the-simualtion-type/
Could you check if the simulation, which you created back then, works the same way with SpaceClaim format? This error is quite annoying, as I use the exact same settings as I used with DesignModeler and yet it gives me a different, non accurate solution.
Thanks in advance and kind regards,
Adam
