In this video, Shared Topology is used to connect the beams to the sheet and solid.
Also, I see you have orthotropic material for the wood. This requires that you define two coordinate systems where each x-axis points along the length of the rail and spar respectively, so that the high stiffness axial direction of the grain is properly used.
You can show your appreciation by clicking Like below the posts that are helpful.
