The unmodified model with 2 elements wouldn't start converging on step 1. The only change I made was to make it 4 elements then it did start converging through step 1. That modified model did not make it all the way. It failed to converge here:
But in this case, the reason it stopped is because the displacement was larger than needed and the part ran into the other wall.
I have attached the ANSYS 19.1 archive that I solved.
