dsurendr
Hello Professor,
This is not possible using ANSYS License Manager to use two different ports for the license file.
Instead you can use an Options file to control the Academic and Teaching licenses.
You can restrict the users from accessing the Teaching licenses by making it available only to specific Groups
It would generally be called ansyslmd.opt file saved under the C:Program FilesANSYS IncShared FilesLicensinglicense_files (default path)
You can refer to any Flexnet options file guide for the synatx to be used in this file.
Any changes made to this Options file would require the restart of the ANSYS License Manager
