pgl
Cool. Glad you are running the latest release. Thumbs up!
So as I understand, the issue is that the Workbench solution status never completes, it gets stuck or slows down to a very very slow pace?
If so then this could be system resources issues, you could be low on RAM or physical disk space. Pop open the Windows Task Manager to see what the system situation is. Also what are the specs of the computer you are using, and how does that compare to the complexity (mesh density, simulation type etc) of the model you are trying to solve? Try and free up as much system resource as possible for ANSYS to "consume" and see if that helps.
