Sandeep Medikonda
Sh ga,
Can you put a small command snippet in your solution as shown:
/show,png
ESEL,S,ELEM,,525
nsle,s,1
/auto /view,1,1,1,1
eplot
This should plot the element of interest:
Now, if you have the real id from your initial contact, you can use the following commands to plot these as well (say for a real ID of 4 in this case and CONTA174 elements)
/show,png
set,2,last
esel,s,real,,4
esel,r,ename,,CONTA174
nsle,s,1
esln,s,1
/auto /view,1,1,1,1
eplot
If none of this helps, see if you are able to take the results to MAPDL and plot them using the commands discussed above:
Hope this helps!
Sandeep
