lliang
The "Injection item" mentioned in the error message can be found at the top of the "Solid_Injector" panel. The icon is a clock plus a cone. You can click this "New Injection" icon to add an injection item for this solid cone injector. Each injection item specifies the injection timing, injection profile and total injected mass of an injection pulse. You can add more than one injection under the same injector to mimic split injection, which consists of multiple injection pulses. Hope this helps.
Best Regards,
Long
