miguwhynot
Hi, okey I'll try to give a deep explanation.
Purpouse: Study the heat transfer during the flight of a ballon untill 32 Km of altitude. The ballon is supposed to move with a +4 m/s in the Y axis.
Geometry: - One fluid volume for the air and one fluid volume for the Helium inside the balloon.
                  - The air volume is a cube whose edge are 20R lenght.
                  - The balloon it's a sphere of R m Radius.
                  - Top cube face will be the inlet and bottom face will be the outlet.
FLUENT: - Time set to transient, since I'm going to simulate the temperature and pressure change with UDFs (code is shown in previous post).
                - Air for the cube, helium for the sphere(cell zone conditions) and film porperties for the ballon skin (applied in wall menu).
                - Velocity inlet (top face): Set velocity to 4 m/s normal to boudary and temperature defined by UDF.
                - Presure Outlet (bottm face): Gauge Pressure defined by UDF(see previous post).
                - Skin-wall: Set as a wall and asigned a thickness, shell conduction considered.
                - Operating Conditions: Set gravity as -9.81 in the Y axis, Operating pressure as 0 and Operating Density as 0.
                - Viscous Model k-epsilon and energy enabled (later on will try to implement radiation if able).
                - Material properties for helium and air: desnity set by the ideal-gas model.
Problems: - When using Pressure Solver, not able to get any results.
                 -  When using Desnity based Solver, anormally high temperature shown in results such as 500 K. When the max temperature                          expected is 288.15 K (could be more with radiation).
                 - In reality the ballon change its size during the fligh.
