raul.raghav
If you want to interpolate the results of one case to another, you can use File --> Interpolate. See attached youtube video to see how it is done:
Transfer Data from One Fluent Case to Another Using Interpolation Files
If you want to import the information at the boundary of one case to another, you can use File --> Write --> Profile and File --> Read --> Profile. See attached youtube video to see how that is done.
Use Profile Files to Transfer Boundary Data
If you're dealing with just a fluid flow simulation, you just need a solid material defined and the properties of the defined solid doesn't matter. If you're dealing with heat transfer or FSI studies, relevant properties of the solid needs to defined. You can edit the material properties under Setup --> Materials --> Solid --> Create/Edit.
