Fabricio,
In one of your recent models, I counted 233 parameters.
I don't believe you have 233 independent parameters. I expect there is a short list of a few (tens of) parameters that are truly independent.
I expect many planes that are created for slicing are dependent on some other plane that is driven by an independent parameter.
You need to construct the DM geometry so the independent parameters are used directly in many plane constructions for slicing.
That will reduce the number of parameters showing up in Mechanical.
