shaheen wahab
Hello
These are the steps that I performed...
1. I imported the points from a text file
2. Used the 3D curve to connect all the points on the curve on that plane
3. Connected the two endpoints of the curve with "Lines from points"
4. Made a plane
5. Projected the sketch of the curve
6. Extruded it and then I rotated and moved it.
The final position should be at the bottom of the channel (inside it) and I am not able to do that.
I failed to perform the Cut/ Slice Material operation or even Boolean.
