Parse error typically means you've got the syntax wrong. If it's a UDF from the manual check for white space characters (HTML & pdf often contain these), if you wrote it check line 2 too.  I'm not entirely sure why you're trying to access the heat exchanger model, and would also recommend updating to R19.
