tsiriaks
Hi Globrother,
Aside from Rob's suggestions, also check if you have any pending Windows update and make sure you install them all. Then reinstall ANSYS again (make sure you remove ANSYS Inc folder before you attempt the new install)
If you still have an issue, please send the screenshot of the output of the command 'set' (without quote '') in the CMD Prompt.
Thank you,
Win
