Hello Robin,
What did you use for your end time?  Try using a small number like 1e-5.
In output controls, the default is to output results at only 20 points between zero and the end time, so if your solution failed before it got to 1/20 of the end time, there would be no results output.  Change the number of points to create output to 2000 instead of 20.
