Fabricio.Urquhart
Peter,
I think that the problem is the bolt's preload. Because it changes depending on the bolt diameter. Is it possible to parametrize the load dependent on the parameter diameter?
Another question. If I run the models separated, with differents preloads, the results will be saved, despite the load is different?
