mashimaro_star
Hi Keyur,
Thank you for the prompt reply. Yes I can open it in Fluen Meshing. The problem is that I can read the mesh using Fluent, perform computation, then save dat and cas. However, if I close the case and want to reopen the case using Fluent, it returns the error I mentioned in the original post.
The "check" and "check the quality" reports are as follows. Could you please see if there is anything I can do? I do not want to read the mesh every time and then read the journal file to recover the case setup... Thank you very much.
Domain extents.
x-coordinate: min = -7.617500e-02, max = 7.110600e-02.
y-coordinate: min = -2.358700e-02, max = 4.558700e-02.
z-coordinate: min = -1.885470e-01, max = 1.561000e-03.
Volume statistics.
minimum volume: 1.747063e-13.
maximum volume: 2.587584e-10.
total volume: 4.123249e-05.
Face area statistics.
minimum face area: 2.478286e-09.
maximum face area: 8.736383e-07.
average face area: 1.365562e-07.
Checking number of nodes per edge.
Checking number of nodes per face.
Checking number of nodes per cell.
Checking number of faces/neighbors per cell.
Checking cell faces/neighbors.
Checking isolated cells.
Checking face handedness.
Checking periodic face pairs.
Checking face children.
Checking face zone boundary conditions.
Checking for invalid node coordinates.
Checking poly cells.
Done.
Minimum Orthogonal Quality = 3.00263e-01
(To improve Orthogonal quality , use "Inverse Orthogonal Quality",
where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
Maximum Aspect Ratio = 1.62759e+01
