September 20, 2018 at 7:06 am
Hi SandeepMedikonda,
Using the External Model does not give me the ability to easily link analysis systems using a GUI. Even though I already looked at an input file for a prestressed modal analysis and used the External model for post-processing in Mechanical Workbench, my goal is to switch to Workbench and implement command snippets.
Regarding code snippets, I think I got the first code snippet to work by leaving out the element type number:
ET,,COMBI214,,0,1 !Unsymmetric bearing in XY-Plane
as it defaults to 1+ current maximum.
For the second code snippet, I thought about getting the current rotational velocity by using the *Get command, but I don't know how exactly.
*GET,frpm,??? ! Get current rotational velocity
fHz = frpm/60
bearing_opt = 3
*if,bearing_opt,eq,3,then
/input,'ansys_bearing_manual_%fHz%','inp','P:Simulation (aktuell)ansysMagnetansys_bearings_rillen',2,0
*endif
How can I get the rotational velocity of the current step?
Best regards
