September 20, 2018 at 8:39 pm
So, after doing that, it actually runs through calculations - but the turbines don't rotate. I tried disabling the dynamic motion of the trailing VAWT, to see if I could just get the front one so rotate, but it doesn't. I took one of the single VAWT projects that worked, added a second, and removed that area from the outer domain. Is there an additional setting that needs to be changed since there are 2 rotating areas? Sorry, I have just been using ANSYS since late summer, so I am unfamiliar with a lot of the possibilities of the program. Here is a pic showing that they are not rotating, but being treated like two stationary cylinders.
Thank you!!!!!
