If you don't have a Modal analysis solution feeding into the setup of a Transient Structural analysis, then you can assign an acceleration to the translational joint.
If you do have a Modal analysis solution feeding into the setup of a Transient Structural analysis, then suppress or delete the Translational joint and load and use a Fixed Support on the bottom of the third rectangular block. Then you can use base accelerations.
