Hi Boyuan,
Are you able to zip up that log file? It should make it much smaller.
RSM Job Logs are cleaned up eventually, so you may not be able to retrieve them.
Could you create a much smaller project that uses the same types of systems and analysis, and run that as well? (one that solves quicker)
I would like to try and compare a successful log to the failed one.
Thank you,
Jake
