DrAmine
The flow rate is the one of 360 degrees. Fluent will use for the effective mass flow through the nozzle your input divided by the azimuthal angle difference multiplied with 2*PI. Regarding the angles: keep in mind that we rely on right hand rule and that counterclockwise is always positive. Just stick to rwoolhou suggestion to get the right range.
